cancel
Go Back   DoItYourself.com Community Forums > Plumbing, Heating, Cooling, A/C, Fireplaces, Air Filtering & Water Conditioning Systems > Fireplaces, Heating Stoves, Flues and Chimneys
Fireplaces, Heating Stoves, Flues and Chimneys Wood-Pellet-Artificial, Propane & Natural Gas
Thread Tools Display Modes
  #1 (permalink)
Old 03-09-05, 05:29 PM
FBIbuilder
Stacked Stone Fireplace Facing
Hi, i was recently fortunate enough to be given large amount of manmade stone that is used for a stacked stone fireplace. I was told all you need to tod to install it is to use a 2 part sand 1 part portland mix and butter the backs of the the rocks and thats pretty much it. Has anyone done one of these before?and if so is that all there is to it? What is a typical sq/ft install price to have this type of job done? Any help would be appreciated.
Thanks,
Roy.
  #2 (permalink)
Old 03-25-05, 10:23 AM
pgtek's Avatar
hi
easyer said than done
firs of all you have to lay the stone on the floor and make up the patern. i usually take a plywood sheet the size of my fireplace and draw it up.
then place the stone on it to see what it looks like.
then when i'm ready you need to have some braces, plywwod strip and some piece of wood for wedge.
Next
the cement
2 part sand 1 part portland mix and i part sealbound. to fast set the cement.
I lay the first row in place then used plywood and brace to hold them to the wall.
YOU DO 1 ROW PER DAY.
next row that where the wedge comes in to hold them in place the applied the plywood strip and brace to hold them in place
or get a macon to do it
cheers
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
