cancel
Go Back   DoItYourself.com Community Forums > Exterior Home Improvement Center > Fences and Gates
Fences and Gates Installations, Repairs and Maintenance.
Thread Tools Display Modes
  #1 (permalink)
Old 04-29-08, 09:21 AM
stockade fence on hill
I am installing a stockade fence that goes up hill . Does anyone have hints on how to go about this ?
The hill slopes for 30 feet and has a 6 foot height difference from top to bottom!
Any and all advice is greatly appreciated.
-Jack
  #2 (permalink)
Old 04-29-08, 02:56 PM
Fence
Stick-build the fence. Do not try to use premade panels on hilly ground. Install the posts. Then install 3 stringers between each pair of posts following the slope of the ground. Nail or screw the vertical boards to the stringers. The top stringer should be about 6 inches below the top of the vertical boards and the bottom stringer about 6 inches above the ground. Keep the posts vertical. Use a short level in the vertical position to mark the end cut on the stringers. Good luck with your project.
  #3 (permalink)
Old 04-30-08, 11:21 AM
stockade fence posts
Installing the posts for stockade fence,should I use cement or just bury in dirt and how deep? Thanks for reply on up hill installation by Wirepuller 38 .
  #4 (permalink)
Old 04-30-08, 04:03 PM
Fence Posts
How high will the top of the fence be above the ground?
  #5 (permalink)
Old 05-01-08, 07:14 AM
Stockade fence;wirepuller38
The fence itself will be 6 feet high! jack
  #6 (permalink)
Old 05-01-08, 03:56 PM
Posts
30 inches deep in concrete.
  #7 (permalink)
Old 05-01-08, 08:19 PM
Speedwrench's Avatar
make your holes at least 6 in deeper than you need then place 6 in of gravel in the bottom of the hole. Place the posts on the gravel and pour concrete around them. the gravel will help to drain water from around the posts and keep them from rotting so quick. i did this with mine and most of my posts are over 20 years old.
true camper quotes" is there dirt under all of these rocks?"
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
