cancel
Go Back   DoItYourself.com Community Forums > Plumbing, Heating, Cooling, A/C, Fireplaces, Air Filtering & Water Conditioning Systems > Evaporative Water Coolers
Evaporative Water Coolers Roof or Window mounted devices used for home, room, area or space cooling. Installations, Repairs, Maintenance, Services and Technical Advice
Thread Tools Display Modes
  #1 (permalink)
Old 10-21-09, 11:13 AM
Gunguy45's Avatar
Topic Moderator
Removing mineral deposits
Well, time to button up the garage cooler for the winter. I'm having a heck of a time removing the mineral deposits this time though. It was manually purged every 12 hrs or so of running this year and it did seem to keep the buildup on the pads down, but the ones on the fins are real bad. Didn't seem to be this hard to remove last year even when I wasn't purging. Did a good cleanup on it about 1/2 way though this season, when I changed pads due to mold (had the water level too high I think)
Normal scraping and brushing got the big buildups but really isn't doing anything to the harder areas.
Tried draining the pan and putting 2 gal or vinegar in, let it run pump only for 2 days. Not much diff. Added some CLR and ran it as well as hand brushing it on several times a day. Not much help.
Finally tried a little metal prep (dilute phosphoric acid basically) applied by brush..well it softened the deposits as well as the paint....lol.
So..is there a magic solution? Or should I just get neanderthal on it with putty knives and wire brushes and repaint the cabinet after all the paint gets damaged?
Oh...and do those inline mineral filters really do anything...or are they just smoke and mirrors?
__________________
Vic
I'm no expert, but don't tell my wife that.
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
