cancel
Go Back   DoItYourself.com Community Forums > Electrical and Electronics > Entertainment Center: TVs, Stereos, VCRs and DVDs
Entertainment Center: TVs, Stereos, VCRs and DVDs Services, Repairs, Maintenance, Operations, Functions and Features. Advice and Suggestions.
Thread Tools Display Modes
  #1 (permalink)
Old 11-28-08, 06:04 PM
Mitsubishi TV colour problems
Mitsubishi model CS-37MX1C without any external change seems to need degaussing. Has a built-in degaussing button pressing activates the degaussing however has no effect. Checked the power supply board where the degaussing is plugged in and has no burnt or loose connections and I also checked the main board where the degaussing transformer is plugged in and yet again nothing burnt of loose. Any suggestions will be appreciated.
  #2 (permalink)
Old 12-01-08, 07:38 PM
Topic Moderator
you need to use an external degaussing coil.The built in one on the set is just strong enough to eliminate any stray magnetic flux lines during the high voltage initial build up.
__________________
craftsman_50
  #3 (permalink)
Old 12-01-08, 11:23 PM
It looks just like the JVC post I did on 11-14-08 sometimes it looks better or worst. Could it be some component otherwise? The problem just started by its self without any outside magnetic source having been placed nearby.
http://s362.photobucket.com/albums/o...t=DSC01150.jpg
  #4 (permalink)
Old 12-02-08, 04:50 AM
Topic Moderator
The only possible causes are a bad connection in the tv degause circuit.Making and breaking connection will cause the degaussing to come on and off whitch could cause it.The other is if for some reason the purity rings on the neck of the crt moved .I'm not certain this tv uses purity rings.
__________________
craftsman_50
  #5 (permalink)
Old 12-02-08, 09:11 PM
Checked the Degausing and it was fine. The problem seems to be environmental; moved the t.v out of the room and everything is fine.
The strange thing is that i replaced the t.v with another one and the problem disappeared.
Thanks for all your help.
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
