cancel
Go Back   DoItYourself.com Community Forums > Electrical and Electronics > Entertainment Center: TVs, Stereos, VCRs and DVDs
Entertainment Center: TVs, Stereos, VCRs and DVDs Services, Repairs, Maintenance, Operations, Functions and Features. Advice and Suggestions.
Thread Tools Display Modes
  #1 (permalink)
Old 11-21-08, 08:46 AM
ge vg 2056 vcr no ffw or revs
from stop it will not ffw or revs. from play it ffw and revs. scuffed and cleaned pinch roller. belt is ok. inserted and ejected tape 20 times to check that cam gear stopped at same place every time.could it be some type of sensors under wheels? put in dummy tape press ffw; pinch roller contacts capstan;it spins a little; pinch roller pulls away ; capstan stops spinning then machine shuts off.
  #2 (permalink)
Old 11-22-08, 04:02 AM
Topic Moderator
I used to fix a lot of vcrs.Problems are almost always mechanical ,belt or corroded mode switch.If you post a pic of the top and bottom of the cassette assymbly I can tell you where to look for the problem when I'm able to see which assymbly it's using.
__________________
craftsman_50
  #3 (permalink)
Old 11-22-08, 08:27 AM
ge vg 2056 vcr
took off drive belt felt a little slack. put on a rubber band just for heck of it . put in tape and it worked. drive belt was streched out. problem fixed. thanks for response' i'll be endind this post now.
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
