cancel
Go Back   DoItYourself.com Community Forums > Interior Home Improvement Center > Energy Usage, Conservation and Weather Stripping
Energy Usage, Conservation and Weather Stripping Fuel-Energy Costs, Conservation and Billing. Door-Window Weather Stripping Installations, Methods-Procedures.
Thread Tools Display Modes
  #1 (permalink)
Old 12-03-08, 02:42 PM
heating the new addition
I built a 2nd floor on my cape, and adding a 2nd heat zone to the hot water baseboard is going to be alot of money. My question concerns the new hydronic electric baseboard heaters. I've heard they cost less to operate than the older electric heat. Since I'm insulated well, and use a wood stove as my primary heat source, I considered using electric baseboard heat upstairs. But in western Massachusetts, that's not usually considered a good option. With the cost of oil, and everything else I mentioned... anyone have an opinion on this? Are these hydronic electric units really less expensive to operate than convention electric heaters?
  #2 (permalink)
Old 12-03-08, 04:50 PM
I'm a little north of you and also have a cape, standard 1970 insulation I have a wood stove set up centrally as I heated with wood only for 10 years. A bit older and in-laws moved in so we heat with oil now with only an occasional fire. BUT the point I want to make, you won't need much heat upstairs if you are well insulated. We have to keep the bedroom doors closed most of the time and that is with so-so insulation. As for cost, the current drop in oil prices is making oil cheaper, oil and electric were on par. As for the "hydronic electric baseboard heaters" there is nothing there to make them more efficient. Maybe a thermal mass advantage that would hold the heat longer and maybe even out the hot/cold changes, but no magic. But as stated above, you won't need much, so the little you will use them, verses the cost of oil, I think you would do fine with the electric units. Running a loop off of your boiler would be better, but the payback could be a long time.
Enjoy
Bud
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
