| Electronic Alarms and Home Security Devices Installations, Repairs, Maintenance, Operations, Functions, Settings, Services and Technical Advice |  03-28-09, 11:24 AM | | Member | | Join Date: Mar 2009 Location: Ont Posts: 15 | | | Safewatch Pro 2000 (Vista-20SE) My system has a defective wireless motion sensor (model 5890). 1) What do I need to do to permanently disable it? 2) Should I wish to replace it, do you recommend I get another 5890 or a wired sensor. It is located within 3 ft of the control box and running a wire would be very easy. I have the installer code and have successfully entered the programming mode. The Programming Guide is brutal. |  03-28-09, 08:07 PM |  | Member | | Join Date: Jul 2006 Location: Moore, Oklahoma Posts: 7,604 | | | I'll try to help you. In the *56 menu enter the zone # that this motion is assigned too. It will then bring up "zone type", enter '00', then * This should disable the zone until you get a replacement. |  03-29-09, 08:48 AM | | Member | | Join Date: Mar 2009 Location: Ont Posts: 15 | | | Stuck in Programming Mode Thank you for the quick response. Tried what you suggested but I'm stuck in programming mode, eg entering *99 doesn't take me back to a Ready status. Also appears in Programming mode, AC is disconnected as the monitor is reading No AC. Any ideas? Update: I'm back on Ready. Did a restart by discoonnecting the power (AC & DC). Last edited by WillGiveItATry; 03-29-09 at 11:25 AM. |  03-29-09, 03:26 PM | | Topic Moderator | | Join Date: Jun 2000 Location: Gainesville, FL, USA Posts: 7,954 | | | You don't have a 6160 keypad or equivalent, do you? You cannot see the zone programming menus from the fixed alpha model keypads like the 6150. __________________ "Ask the Right Question..." - from _The Snow Queen_ by Joan D. Vinge- |  03-29-09, 06:48 PM | | Member | | Join Date: Mar 2009 Location: Ont Posts: 15 | | | Not sure what model it is but suspect you are correct - after I entered *56 I didn't get any alpha characters that would help me out. Update: I did some searching on the internet. My keypad is closest to the 6149EX. It is branded ADT. Last edited by WillGiveItATry; 03-29-09 at 08:34 PM. |  03-30-09, 11:30 AM | | Topic Moderator | | Join Date: Jun 2000 Location: Gainesville, FL, USA Posts: 7,954 | | | In this case, the specific doesn't matter much. You have a fixed alpha keypad. In order to access the zone programming menus you need the 2-line alpha keypad like the 6160 or 6139. __________________ "Ask the Right Question..." - from _The Snow Queen_ by Joan D. Vinge- |  03-30-09, 05:54 PM | | Member | | Join Date: Mar 2009 Location: Ont Posts: 15 | | | Thanks - That must mean when ADT came in previously to re-program my service they brought another keypad. Does this seem right to you? I can't believe they stiffed me with one without full functionality especially when they knew I would own the system at the end of the initial term. Had they told me about the difference in functionality and price, I suspect I would have paid the difference. |  03-31-09, 11:46 AM | | Topic Moderator | | Join Date: Jun 2000 Location: Gainesville, FL, USA Posts: 7,954 | | | Yes, their standard business model is to bring in a programming keypad and sell the fixed alpha on the entry level systems. They charge a premium for the full alpha model. __________________ "Ask the Right Question..." - from _The Snow Queen_ by Joan D. Vinge- | | Thread Tools | | | | Display Modes | Linear Mode | Posting Rules | You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -7. The time now is 05:20 PM. | Sign up for our FREE newsletter! Find Qualified Local Contractors Sponsored Ads |
