cancel
Go Back   DoItYourself.com Community Forums > Electrical and Electronics > Electronic Alarms and Home Security Devices
Electronic Alarms and Home Security Devices Installations, Repairs, Maintenance, Operations, Functions, Settings, Services and Technical Advice
Thread Tools Display Modes
  #1 (permalink)
Old 01-14-09, 04:21 AM
Help? VISTA 10SEa Security System in Oz
Hello all
Having recently separated from my wife, I was wanting to delete her alarm code and change mine.
I was not able to locate the MASTER CODE anywhere in my documentation, but located information on this forum about accessing the programming by turning system off at power, disconnecting battery and then restarting and within 50 seconds, hitting "*" and "#" simulateneously. Then #20 for what must be my master code.
I now have a code, but -
a) I have a CHECK warning on "09" that won't go away
b) I can BYPASS the "09"
c) And the code doesn't seem to work as I can't delete the old user codes, or change the master code to something else. When I try by entering MASTER CODE + 8 + 2 + NEW CODE + NEW CODE, I only get two numbers through the second new code when it beeps at me 3 times... 2 digits too early!!
Any suggestions???? Please???? This is driving me nuts.
  #2 (permalink)
Old 01-14-09, 05:27 AM
Topic Moderator
The arm/disarm code you were originally using was, most likely, the master code. What you obtained was the _installer_ code.
You could have changed the code with the one you had, but the installer code will do the job also.
I suspect that you tried to change the code without exiting program mode with *99, and in the process turned on the RF system type in *22 without having a wireless receiver, and possibly altered other programming elements.
My best advice is to go back into programming with [installer code] + 8 + 0.
Then use the the programming form and the View function (# + location number) to sort out what you may have changed.
__________________
"Ask the Right Question..."
- from _The Snow Queen_ by Joan D. Vinge-
  #3 (permalink)
Old 01-14-09, 05:46 AM
Okay, thanks.
I went to try and do that...
The code I got first time round is not allowing me into the programming.
I can only access the programming using the turn off trick.
I am the second houseowner, but I don't remember how I programmed a code for my wife and I...
Grrr.....
These things shouldn't be so difficult!
  #4 (permalink)
Old 01-14-09, 07:22 AM
Happy Face
MrRonFL
You are a dead-set legend - I think you were right about the RF.
I reprogrammed a few functions, and now all is good!
I have a new installer code, master code, and a single new access code.
Thanks for your help!
Justin
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
