| DSC Power 832 and Smoke Detectors I have a DSC Power 832 system and had to reprogram the system. I had no problem with the alarm portion of the system, but I'm having difficulty with the smoke detectors. the smoke detectors are System Sensors model 2100TS. I have two detectors...one in the kitchen and another in a hallway, the one in the kitchen was removed due to work in that room. The kitchen unit has 2 sets of wires coming into it. I'm assumming one set of wires to the control box and the other to the detector in the hallway (note: the detector in the hallway only has 1 set and a resistor at the end). the wire in the control box is wired for a two wire set...red to Aux+ and black to Prg2. The detector has 5 connectors +,+,-, +led, -led. Question, how do I wire the the smoke detector (which terminals) and second, how do I program the panel to recognize the smoke detectors (note: I have the installers code as I had to reprogram the system) Thanks in advance |
