cancel
Go Back   DoItYourself.com Community Forums > Electrical and Electronics > Electronic Alarms and Home Security Devices
Electronic Alarms and Home Security Devices Installations, Repairs, Maintenance, Operations, Functions, Settings, Services and Technical Advice
Thread Tools Display Modes
  #1 (permalink)
Old 11-16-08, 08:27 AM
Vista 10P..........Resetting
Is it possible to reset the 10P to the original factory default settings and start over with the programming once I get the 6160 Keypad. I tried programming with the 6150 and have got a mess.
Thanks in advance
  #2 (permalink)
Old 11-16-08, 12:05 PM
PRO1 TECH's Avatar
try this *96 & *97
  #3 (permalink)
Old 11-16-08, 02:28 PM
Thanks Pro Tech.......I guess I just overlooked that in the Installation and Setup Guide. I have to admit, by the time I was done with the installation of the system (wiring, mounting equipment) and then trying to program with the 6150....I was a little more than frustrated and just simply overlooked the info that you referred me to.
Thank you very much!
Vern.........the xrated one
  #4 (permalink)
Old 11-16-08, 02:34 PM
PRO1 TECH's Avatar
any time i can help i will
  #5 (permalink)
Old 11-16-08, 05:18 PM
Pro1 Tech......Thanks again for the reply. I reset the unit to the factory defaults and then programmed in my entry/exit delays, etc and I've got it working. It's a very simple setup for my detached garage and I only have two zones in use, so the factory settings will work for my application. Thanks again.
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
