| Electronic Alarms and Home Security Devices Installations, Repairs, Maintenance, Operations, Functions, Settings, Services and Technical Advice |  07-13-08, 01:48 PM | | Member | | Join Date: Jul 2008 Posts: 1 | | Vista 20se Pager Characters - *88 If this info exists on the site, I can't find it. I have teminated my contract with ADT and am trying to set up my Safewatch 2000 (Vista 20se) to dial my Verizon cell phone, and leave a numeric page. Thanks to the great info on this site I have deleted the primary number (*41) and put my cell number in the secondary number (*42), and set the split/dual mode (*49) to 6. The panel is calling my cell number, which is great as long as I have my cell on, but it will not leave a page. In order to go into paging, it needs to dial 5 when it reaches voice mail. I tried putting all fives in the primary subscriber field (*43), but that does not seem to work. Then I stumbled upon a programming field that is not listed in any of the manuals or programming guides (*88, Paging Characters). I did find a reference to this in the Ademco Lynxr manual, but it uses it as a prefix to a 7 digit page (unlike the 10 digit page of the 20se). When I hit *88 my keypad says "paging chars", and allows me to input up to 16, including pauses and * and #, so I can definitely use this to get into my paging system, but is there any special code I need so that these characters will be sent, do I need to delete my subscriber ID? If this field can be used, this may be helpful to others who are trying to page with the 20se. |  07-13-08, 02:03 PM | | Topic Moderator | | Join Date: Jun 2000 Location: Gainesville, FL, USA Posts: 7,950 | | | Give it a try. If it works, it will work the same way as the Lynx version; it's the keystrokes you need to send after the paging system picks up. Interesting, that one isn't in either the V20se manual or the SW 2000 manual.... __________________ "Ask the Right Question..." - from _The Snow Queen_ by Joan D. Vinge- |  10-25-08, 11:33 AM | | Member | | Join Date: Oct 2008 Posts: 4 | | | Trying to do the same did you ever get this to work - mine calls 8 times but no pager info. |  10-25-08, 01:47 PM | | Topic Moderator | | Join Date: Jun 2000 Location: Gainesville, FL, USA Posts: 7,950 | | | If it is calling 8 times, then you don't have it setup for pager. Do you have a Vista 20se/SW2000, or do you have a Vista 20p/SW3000? The procedures are not interchangeable between the models. __________________ "Ask the Right Question..." - from _The Snow Queen_ by Joan D. Vinge- |  11-12-08, 08:06 PM | | Member | | Join Date: Oct 2008 Location: Canada Posts: 16 | | | Is it possible to have it just ring twice 8 times seems excessive. Also does the "line grab" last until it has made oll 8 calls and what does the FC on the display mean? Thanks |  11-12-08, 08:15 PM | | Topic Moderator | | Join Date: Jun 2000 Location: Gainesville, FL, USA Posts: 7,950 | | | As I said above, if it is dialing 8 times, then you have the pager connection setup incorrectly. A pager setup will only dial once. When you answer the call, it stops. __________________ "Ask the Right Question..." - from _The Snow Queen_ by Joan D. Vinge- |  11-13-08, 03:34 PM | | Member | | Join Date: Oct 2008 Location: Canada Posts: 16 | | | So..you should use *42 then add some numbers to the secondary subs acc? (customer code) for it to ring just once? |  11-13-08, 04:58 PM | | Topic Moderator | | Join Date: Jun 2000 Location: Gainesville, FL, USA Posts: 7,950 | | | Ok, I had to search your prior posts, Kranker, to find out what model you have (no I don't remember individual posts). As I said, the commands vary by system model, so you should indicate your system model when you tag onto the end of an existing thread. You have, apparantly, a SW 2000/Vista 20se. *41 should be blank *42 should have you phone number *48 should be 7 for Contact ID *49 should be 6, 7, 8, or 9 (depending on what you want the system to call out for) (for this purpose, the account codes don't matter) __________________ "Ask the Right Question..." - from _The Snow Queen_ by Joan D. Vinge- | | Thread Tools | | | | Display Modes | Linear Mode | Posting Rules | You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -7. The time now is 07:22 AM. | Sign up for our FREE newsletter! Find Qualified Local Contractors Sponsored Ads |
