Thanks for the quick reply! Some additional notes and questions are below.
Quote:
Originally Posted by ibpooks The code basically allows you to leave K&T circuits as-is or to replace it with modern wiring. Piecemeal upgrades really aren't allowed. My recommendation is to abandon the K&T and install new modern circuits where they are needed. I do not recommend interconnecting the new and the old. |
Unfortunately, a piecemeal upgrade is what the house had when I bought it. The service entrance has been upgraded recently, and all circuits started as romex from the service entrance, but most of these circuits have a junction box which connects into K&T wiring. So most of the circuits were already a hybrid of Romex and K&T. One circuit even starts as romex, moves to K&T in a basement junction box, and then moves back to Romex in the attic!
I am gradually fixing this. What I'm doing is removing the K&T from one circuit at a time and running Romex to the same fixtures and receptacles that the K&T parts of the circuit were previously supplying. In most cases I'm fishing romex through the same holes that I just pulled the (now dead) K&T out of.
Also, while I'm working on each circuit, I'm replacing any ancient fixtures, switches, and receptacles which don't support proper grounding, and also replacing ancient boxes with to-code-or-larger modern boxes.
Overall, does this sound like a reasonable approach?
re: the rules for closet light fixtures, I think I'm OK with these three:
1) enclosed fixtures - currently planning to use enclosed, surface-mount incandescent fixtures in all closets except one where I only have 10" clearance, there I'll use surface-mount fluorescent.
2) 12" clearance - all current fixtures are mounted over the doors, 2+ feet from shelf space in all cases but the one I mentioned above.
3) 90-degree wiring - this is OK, since there won't be any K&T on these circuits (or any old romex either) once I'm done.
But the wall-switch requirement has me worried. And adding 4 closets' worth of wall switches is a lot of additional work I'd love to avoid if possible, but I'll do it if I must.
But I'm not adding a fixture, only upgrading the fixture and upgrading the wiring between an upstream junction box and the fixture. Does that constitute enough of a change to make the wall-switch requirement kick in? Or can I simply replace the existing bare-bulb, pull-chain closet fixtures with enclosed, pull-chain fixtures?
