cancel
Go Back   DoItYourself.com Community Forums > Electrical and Electronics > Electrical - A/C & D/C
Electrical - A/C & D/C Wiring, Junction Boxes, Switches, Receptacles, Fuses, Breakers, GFI'S, Main & Sub Panels.
Thread Tools Display Modes
  #1 (permalink)
Old 08-20-09, 12:40 PM
Question Wiring a tubular heating element to 220v?
I need help wiring a typical heating element for an electric oven to 220v from a thermostat with only two connections. I think this is used as a trigger.
I need to know if one 110v wire goes to one side of the heating element and the other wire goes to the the thermostat to act as the switch to turn on the second 110v wire.
Will this give me the proper connection, to give me a 220v heating element?
Thanks to anyone in advance.
  #2 (permalink)
Old 08-20-09, 12:45 PM
Yes that sounds correct, the thermostat is only breaking one leg of the 240 volt circuit.
  #3 (permalink)
Old 08-20-09, 03:06 PM
Thank you, wirenut. Does anyone else have anything to say, though? I'd like to be absolutely sure about this.
  #4 (permalink)
Old 08-20-09, 03:19 PM
I know it's correct, would it have made any difference if I didn't say "sounds correct"?
You'll need to wire it up correctly. One hot will go straight to the element and the other hot will go to the t-stat then to the element
Sorry, I like to speak in simple terms and answer the question directly.
  #5 (permalink)
Old 08-20-09, 04:14 PM
Topic Moderator
Wirenut's procedure is correct.
__________________
Good luck with your project!
-Ben
  #6 (permalink)
Old 08-20-09, 10:35 PM
I'm sorry if I offended you, wirenut. I'll give this a try tomorrow.
  #7 (permalink)
Old 08-21-09, 12:12 AM
Well since you asked for opinions you don't have any 110v wires. You have two 240v wires.
Tags
110, 220, heating, oven, thermostat
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
