Yet another thermostat wiring question. Newbie needs help. Hi All, I've been searching through prior threads without luck. I'm not sure how to properly connect my new thermostat and could use your expert advice. The situation: SYSTEM Simple electric wall heater; no AC or anything fancy. Three wires from wall (2 black, 1 white). OLD THERMOSTAT SETUP Black#1 (from wall) to Red (on old thermostat) Black#2 (from wall) to Black (on old thermostat) White (from wall) to White (on old thermostat) NEW THERMOSTAT OPTIONS (instruction manual notes) W (heating; not for heat pumps) RH (24 volt) RC (24 volt cool) G (fan) Y/Y1 (AC compressor) O/B (reversing valve for single stage heat pumps) QUESTION On the new thermostat, where should the 2 black wires and 1 white wire from the wall connect? I'm guessing white to W, and black#1 to the RH. But what about black#2? Should that go to RC? Note: the RH and RC have a jumper wire connecting them by default. Thanks for any help! |
