cancel
Go Back   DoItYourself.com Community Forums > Electrical and Electronics > Electrical - A/C & D/C
Electrical - A/C & D/C Wiring, Junction Boxes, Switches, Receptacles, Fuses, Breakers, GFI'S, Main & Sub Panels.
Thread Tools Display Modes
  #1 (permalink)
Old 01-08-09, 10:27 AM
Daisy Chaining?
I want to install 6 overhead lights in my Garage. The ones I am looking at already have 3 prong plugs on them with short leads. I want to install outlets in the ceiling (unfinished) and then plug these into the outlets ( 1 per outlet). Will I need a dedicated circuit for each or can I daisy chain two or more together. They are 4' flourescent fixtures with 2 bulbs each.
  #2 (permalink)
Old 01-08-09, 10:38 AM
Gunguy45's Avatar
Topic Moderator
I'm sure you can if done correctly, I'd let the Pro's answer you completely. Prob need GFI protection.
What I was really replying to say is...don't just put them all on one switch. Depending on how the are arranged, I'd suggest 2/2/2 or 3/3. You prob won't always need all the lights on at once, and if gives you more flexability for the cost of a few feet of wire and a couple of extra switches.
__________________
Vic
I'm no expert, but don't tell my wife that.
  #3 (permalink)
Old 01-08-09, 10:40 AM
You shouldn't need a separate ckt for each lamp. Add up the amp rating of each lamp, and from that you can decide how to proceed. You very well might be able to put them all on one new ckt or even on an existing ckt.
Doug
  #4 (permalink)
Just bring your switch leg from your switch to the first recept. and then from there to the next in line until you get to the last one where you will have only one romex in that box. I wouldn't think you would need a dedicated circuit depending on what all is already on the existing cir.
  #5 (permalink)
Old 01-08-09, 10:42 AM
pcboss's Avatar
Topic Moderator
There is no need for a circuit for each light. One circuit could serve all six. If your area is under the 2008 Code edition the receptacles would need GFI protection even though they are not readily accessible.
I like the idea of multiple switches too.
__________________
All answers based on National Codes. Please check with your local building departments for local amendments.
  #6 (permalink)
Old 01-08-09, 02:21 PM
Quote:
Add up the ballast input amp rating from each light fixture.
  #7 (permalink)
Old 01-09-09, 10:35 AM
Thank you
Good advice all, I am waiting for some warm weather to try it out. I will add up the amperage to make sure i dont overlaod something if they are all on at once. I will be using 1 circuit for the GFI's. Will I need 12 awg or can I use the 14 gauge wire? Each has a pull chain, but I like the idea of a separate switch for the 3 banks.
I will let you all know how it goes or if I get stumped with it.
Thanks again.
Bud
  #8 (permalink)
Old 01-09-09, 12:54 PM
Topic Moderator
Quote:
You can use either as long as you use the right size breaker.
#14 wire is rated for a 15A breaker (1800W of lighting)
#12 wire is rated for a 20A breaker (2400W of lighting)
__________________
Good luck with your project!
-Ben
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
