Quote:
Originally Posted by robushey is there a way to determine externally (without removing the plugs or switches) if an outlet is grounded? |
A receptacle that is ungrounded should have just two slots, not three. Ungrounded, 2-wire receptacles are still available, although they should not be used for new work. So, after you determine which outlets are ungrounded, you may need to replace the receptacle.
GFCIs are available only in three-wire versions. They come with stickers that say "No Equipment Ground," and such a sticker should be afixed to the GFCI cover plate if used in ungrounded circuits.
Doug
