cancel
Go Back   DoItYourself.com Community Forums > Electrical and Electronics > Electrical - A/C & D/C
Electrical - A/C & D/C Wiring, Junction Boxes, Switches, Receptacles, Fuses, Breakers, GFI'S, Main & Sub Panels.
Thread Tools Display Modes
  #1 (permalink)
Old 08-09-07, 08:41 PM
Electric Cooktop install 220V
Existing supply; 2 50A breakers
Black, Red, White insulated wires
Metal flex cable to junction box
black/red 220V
red/white 120V
black/white 120V
Old cooktop Black to black, red to red, copper (no insulation) to white
New Cooktop(Bosch 74net) has red/black/white/green insulated wires
I assume black/red/white go to same, where goes green?
Appreciate it?
  #2 (permalink)
Old 08-10-07, 06:43 AM
First and most important. I hope you are mistaken, and that you have one breaker. You cannot have separate breakers for this, you need a single breaker.
The proper and best solution is to replace the existing cable with a new cable containing four wires. Is this possible?
  #3 (permalink)
Old 08-10-07, 07:04 AM
220V cooktop
Breakers are adjacent to each other and both move as one,
Unable to replace existing cable run unless absolutely necessary.
thx!
  #4 (permalink)
Old 08-10-07, 07:07 AM
Follow the directions that came with the cook top about connecting it to a three wire connection. These directions will tell you about bonding the shell to the neutral wire.
  #5 (permalink)
Old 08-10-07, 09:12 AM
Topic Moderator
Most cooktops and ranges have instructions for both three- and four-wire hookups. Follow the instructions for three-wire hookup. If your cooktop does not have instructions for three-wire hookup, then you need to either run a new four-wire cable or find a new cooktop.
__________________
Good luck with your project!
-Ben
  #6 (permalink)
Old 08-11-07, 09:13 AM
220 cooktop
Installation instructions :
"Frame grounded by connection of grounding lead to neutral lead"
Does this mean i can connect both the green insulated and white insulated on new cooktop to white wire of old?
Previous top had un insulated ground to white wire of existing.
Is there a method of checking whether the exising cable and metal junction box is grounded?
If so, could the green wire be attached to the flexible conduit or the junction box?
Appreciate all the help!
  #7 (permalink)
Old 08-11-07, 11:08 AM
Topic Moderator
For three-wire installation, yes.
With the power to the circuit off, use your multimeter or ohmmeter to check for continuity between the white neutral wire and the metal box. Your metal conduit may actually provide a suitable ground. Can you identify if the existing cable is individual conductors in conduit or BX cable?
> junction box?
It would be connected to the metal junction box by way of a self-taping green ground screw (available in the electrical aisle).
__________________
-Ben
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
