| Ducting Systems and Air Ventilation Ducting Installations, Repairs and Maintenance. |  10-28-09, 05:59 PM | | Member | | Join Date: Oct 2009 Location: Illinois Posts: 6 | | | Dryer duct distance to window My dryer duct is 18 inches to the left of my basement window, The window can be opened, is there any codes specing the minimum distance. does this present a dangerous situation. Thanks Matt |  10-28-09, 08:38 PM |  | Member | | Join Date: Dec 2005 Location: VA Posts: 3,173 | | | Not in my area, but I would check with your local code because everywhere is different. |  10-28-09, 09:32 PM | | Member | | Join Date: Mar 2009 Location: WA Posts: 673 | | I agree with Airman, the old UBC code is within 3' of building openings. If a gas dryer, I would not have it that close as the gases after combustion could cause health problems or death if under the right conditions. Check your County's web site, it may look like this one: http://www.hcpdc.com/pdf/Dryer%20Ven...quirements.pdf Be safe, Gary |  10-30-09, 10:08 AM | | Member | | Join Date: Oct 2009 Location: Illinois Posts: 6 | | | I can't find any codes restricting it, but I still don't feel comfortable about it. Oh well, out comes the hole saw. If only it was that easy, Thanks for the help Matt |  10-30-09, 10:14 AM |  | Topic Moderator | | Join Date: Dec 2007 Location: Northern AZ Posts: 6,977 | | | Well, it CAN be opened..but is it ever actually opened? __________________ Vic I'm no expert, but don't tell my wife that. |  10-30-09, 10:46 AM | | Member | | Join Date: Oct 2009 Location: Illinois Posts: 6 | | | rarely. I was more concerned with not being in code than anything, |  10-30-09, 12:47 PM |  | Topic Moderator | | Join Date: Dec 2007 Location: Northern AZ Posts: 6,977 | | | Well..instead of having to drill one hole, and patch another..I'd investigate with your local building department. You might be able to just screw the window shut (assuming its not required for egress). I've seen tons of dryers that were vented though a piece of plywood placed into a window opening. Just seems like a lot of work for something that may not be an issue. But..if it gives a little comfort in your life...go for it! We can all use a little more of that...right? __________________ Vic I'm no expert, but don't tell my wife that. |  10-30-09, 09:34 PM | | Member | | Join Date: Mar 2009 Location: WA Posts: 673 | | | Here are some more, only if gas dryer: Venting systems terminate not less than 4’ below or 4’ horizontally from, and not less than 1’ above a door, an operable window or a gravity air inlet into a building, nor less than 3’ above any forced air intake within 10’, nor within 12” of grade. (M1804.2.6 & G2427.8 ) Vent terminal not mounted directly above or within 3’ horizontally of a gas meter or oil tank. (M1804.2.6) Vent terminal no closer than 3’ to an interior corner formed by (2) perpendicular walls. (M1804.2.6) Be safe, Gary |  11-02-09, 05:06 AM |  | Member | | Join Date: Nov 2009 Location: N.C. USA Posts: 120 | | | Dryer exhaust If it is a gas dryer yes i would be Most contractors put it in the easiest spot But please keep it at least 4 ft away from your a/c or it will suk right into it 4 ft away from everything would be great if it can be done or keep that window closed |  11-03-09, 09:07 AM | | Member | | Join Date: Oct 2009 Location: Illinois Posts: 6 | | | I decided to move it, I was able to remove a brick and using the same brick, patch the old hole. Without knowing I did it, You can't tell were the original termination was. It was one of those things that you rather not have to do, but it keeps eating at you. Thanks for the motivation. Matt | | Thread Tools | | | | Display Modes | Linear Mode | Posting Rules | You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -7. The time now is 11:27 PM. | Sign up for our FREE newsletter! Find Qualified Local Contractors Sponsored Ads |
