cancel
Go Back   DoItYourself.com Community Forums > Interior Home Improvement Center > Doors and Windows
Doors and Windows Installations, Maintenance & Repairs.
Thread Tools Display Modes
  #1 (permalink)
Old 10-23-09, 03:02 PM
Angry PLZ HELP...Time sensitive Veneer door stain
Heavy Veneer Doors (Commercial) Im having a prob with dust getting in the min-wax poly-shade (Dark) I'm using. I've tried using lemon oil and 600 grit to get it clean and smooth which worked well but it's leaving a white haze on the finish. Im also experiencing brush marks but should be able to fix that. Also should I be using a sanding sealer and/or wood conditioner? Please help its time sensitive. Im going gray by the hour.
  #2 (permalink)
Old 10-23-09, 04:59 PM
XSleeper's Avatar
First, you can't work in a lint / dust filled environment and expect to have a perfect finish. And you probably don't want to wipe on any sort of oily product other than paint thinner... and you would only do that after the finish had a good 24 hours to dry, which is the time I would suggest you allow between coats of finish. Don't use fans to circulate air either, that will only speed the amount of lint and dust flying toward the product.
Personally I avoid polyshades like the plague and only use it if I can spray it on.
Sanding sealer can be used as an initial coat, which seals the wood and sands easily, providing a nice smooth surface. But between coats of polyshades, you should still be lightly sanding with the grain, using 220 grit. 600 is too fine. After you sand, wipe with a rag lightly moistened with thinner.
Wood conditioner is used with soft woods like pine and helps eliminate blotching- sharp areas of contrast that show up when you stain. If you are using polyshades you are probably not staining, and you would not use conditioner.
Tags
door, finishing, polyshades, stain, veneer
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
