cancel
Go Back   DoItYourself.com Community Forums > Interior Home Improvement Center > Doors and Windows
Doors and Windows Installations, Maintenance & Repairs.
Thread Tools Display Modes
  #1 (permalink)
Old 10-08-08, 01:35 PM
Input on installing new replacement Vinyl Single Hung Milgard Windows
I have received our Single Hung replacement Milgard windows to go where we have the original 1955 double hung wood windows. I will be installing these from the outside in but wanted to know what everyone recommends. Here are some steps I think I need to do but no 100% sure.
Steps to prep existing window
Remove Blind Stop
Remove Sash Channel
Take out existing windows
Clean up inside framing
Milgard window install
Predrill holes on sides of vinyl framing
Place window in existing frame
Shim up and balance
Screw in long drywall screws painted white on heads
Caulk around window
Install trim on exterior where blind stop would have been
Caulk around trim
  #2 (permalink)
Old 10-08-08, 03:58 PM
XSleeper's Avatar
If you have a removable interior stop, I'd suggest you install them from inside. If the stop is behind the casing, then you have everything basically correct installing from the outside.
I wouldn't use drywall screws... get yourself some 2 or 2 1/2" stainless steel screws. By all rights, your windows should have come w/ their own installation screws. And don't use silicone anywhere it will show where you will need to paint!
  #3 (permalink)
Old 10-08-08, 09:04 PM
What is the advantage of installing from inside out? Here is a pic of what all my windows look like throughout the house.
  #4 (permalink)
Old 10-09-08, 04:56 AM
The inside stop can be easily removed/reinstalled. The outside stop is actually part of the window frame and has to be sawed off or otherwise chewed off. The center parting bead is nailed in placed and is easily pryed out. The outside stop provides a more substantial stop for the window and allows someplace to caulk, which makes for a better weatherseal. And don't forget to seal the airspace between the new window and old frame. Use DAP foam or non-expanding foam. And as suggested above, there should be stainless screws supplied with the window, and there should predrilled holes in the side frame.
Your picture shows a window of about the 30's or 40's, but I don't see weight pockets, am I missing something??
  #5 (permalink)
Old 10-09-08, 07:22 AM
Well I hope I can install from inside out now that I already have the windows. The house was built in 1955 and there are two sashes up the upper section of the frame.
Which DAP Foam product do you recommend DAP Foam and why do you say non-expanding like Great Stuff?
Thanks for all the input
  #6 (permalink)
Old 10-09-08, 02:05 PM
What kind of foam does everyone like to use that can be easily found and reasonably priced? Dispensing guns or straw cans.
DAPtex Plus Window & Door Foam Sealant
DAPtex Latex Insulating Foam Sealant
Hilti CF 812 Window & Door Pro Foam
GREAT STUFF PRO Window & Door
  #7 (permalink)
Old 10-09-08, 02:53 PM
I like the DAPtex Plus window and door. Water cleanup of any mistakes. Expands, but doesn't overexpand. Stays flexible.
It does need a cleaner surface to adhere than the solvent based stuff, in my experience.
About $5 (?) a can in the paint department of most places. One can will normally do a patio door. Can't say for windows, guess it depends on the size. My can says 510 ft at a 1/4" bead size.
btw...heres my thinking. Yes, filling the whole space is good, but I don't think it makes THAT much difference. A bead of foam at the outside of the frame then a bead on the inside, should (if done well) create a dead air space. I don't think that extra 1" or so of foam will change a lot. Better to make sure your caulking is done very well. Water will do more damage than a little bit of cold air.
It's your money though...it might be more important than I think. Prob a little harder to do with a replacement window also.
  #8 (permalink)
Old 10-10-08, 06:53 AM
Is a foam Backer rod recommended too?
  #9 (permalink)
Old 10-10-08, 08:19 AM
Shouldn't be needed, thats really only for caulking large deep gaps or cracks. There are other uses, of course, but thats whats it was made for.
Are you using the head expanders on the windows?
  #10 (permalink)
Old 10-10-08, 09:03 AM
To be honest I don't know because the windows are still in their pkging off the truck. Not sure if there is extenders or hardware. I'm going to be installing these tomorrow so I was going to get DAPtex Plus window and door & some stainless steel screws.
HTML code is On
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Content Relevant URLs by vBSEO 3.2.0
