cancel
Go Back   DoItYourself.com Community Forums > Interior Home Decorating and Design Center > Decorating and Design
Decorating and Design General color selection & coordination, furniture arrangement & overall home decor
Thread Tools Display Modes
  #1 (permalink)
Old 11-04-09, 08:07 AM
Painting trim the same color as walls
Any thoughts on if it would be ok to paint the trim the same color as the walls? I am painting a small home office which has one window. I was thinking it may make the room look a little bigger if I don't paint the trim a different color. I don't think I have ever seen this done though not sure I have looked specifically when over peoples houses.
Does anyone have ideas on this?
Thank you!
  #2 (permalink)
Old 11-04-09, 08:13 AM
Topic Moderator
Welcome to the forums!
That used to be done all the time and probably still is on some of the less expensive housing. You don't want to use the same paint on the woodwork that you use on the walls. The trim should be painted with enamel [any sheen]
__________________
retired painter/contractor avid DIYer
  #3 (permalink)
Old 11-04-09, 08:35 AM
pmgca's Avatar
Topic Moderator
Hi tcalv,
Depends a lot of the type of room, lighting, style, etc.
For example, if you have a modern style office, with chromed furniture, then a white trim over white walls will look great. But if the style of the office is clasic, with heavy wood furniture, then a white trim over white walls will look odd.
If you wish to post a picture, I will be glad to provide additional advice
In order to set an image here follow these easy steps-->
1 - upload your picture to a free online photoalbum like Photobucket or Flickr , for example
2 - Look for the link of your picture (usually, photoalbums provide a "link for a forum" script) --> copy the full URL to the image, (not the page on which the image is located),
3 - In the DIY Forum--> Reply post or open a new post--> Press the 'Insert Image' icon above and paste the link--> or type [img] before the URL and [/img] after it, ensuring that you do not have any spaces before or after the URL of the image
__________________
Good luck with your project!
Patricia
  #4 (permalink)
Old 11-04-09, 08:58 AM
Pictures
Thank you so much for the info on how to post pics.
Attached are the pics of the room. I have a small desk armoire which is a very light wood color. That will be the only wood piece in the room. I also have two cream color fabric chairs. The rest of the decor will be black/silver colors. Maybe a black framed mirror to make the room look bigger.
  #5 (permalink)
Old 11-04-09, 10:56 AM
pmgca's Avatar
Topic Moderator
From the chromatic point of view, a white on white set is not bad for an office, or perhaps you can think about some gray hue
However, from the decoration point of view and considering the floor, I'd suggest a marble / clear cream combination with the window trim and shade
Something like this
(sorry for the pixel / circle effect on the image)
__________________
Patricia
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
