| Cleaning and Stain Removal All Fabrics, Materials, Methods, Surfaces, Interiors and Exteriors. |  02-25-05, 03:31 PM | | | | how to clean pen marks off microfiber couch we purchase a microfiber couch a few months back, today a contractor came to give us a quote on our back yard, and well he had a pen in his back pocket and left a nice 5 inch black pen mark on our couch. Does anyone know the best way to clean this mark off without causing damage to the couch? Your help would be appereciated. Regards, Nate |  02-26-05, 01:05 AM | | Member | | Join Date: Aug 2004 Location: Vancouver, Canada Posts: 1,247 | | Alcohol (any hard alcohol on hand or dilute methylated spirits for same effect) is safe on microfibre, and recommended for ink stains. You can also use household-strength ammonia. Microfibre cleaning: http://www.taf.com.cy/main/default.a...emID=5&mid=257 Your microfibre upholstery is likely polyester fibre (only smaller), so it can probably take the same treatments. It's impervious to some powerful solvents, while others melt it. All manner of liquids are sold in polyester containers (e.g. P.E.T.), including most solvents. Last edited by Kobuchi; 02-26-05 at 01:21 AM. |  02-26-05, 10:16 AM | | | | Kobuchi, thanks for the reply my wife will be grateful for your help. Nate |  02-26-05, 10:36 AM |  | Members | | Join Date: Jul 2003 Location: N.E. Arkansas Posts: 8,177 | | | Before using ANY solvent or cleaner please check for reactions/compatibility on an inconspicious area before using in an area that will be seen. |  02-27-05, 02:03 PM | | Member | | Join Date: Aug 2000 Posts: 17,214 | | | If ink was permanent, the mark will tend to be permanent. Rubbing alcohol is very effective for removing nonpermanent ink. Test first in inconspicuous area for ill effects. Blot with white rag from outside stain toward middle to prevent spreading. Microfiber is noted for its stain resistance; thus, if ink is nonpermanent, you should have success. |  03-28-06, 08:35 AM | | | | thank you I found this reccomendation while browsing in panic to remove the pen from my new microfiber couch (my hubby had a pen in his pocket!) The rubbing alchol worked perfect. Thanks again. |  01-20-08, 10:20 PM | | Member | | Join Date: Jan 2008 Posts: 1 | | | I found the rubbing alcohol works wonderfully!! I too was in a panic searching for answers, after my two year old daughter attacked our new microfiber couch with an ink pen. With a little extra rubbing it all came out. Thank you guys so much for this website and all the responses! |  01-22-08, 10:13 PM |  | Topic Moderator | | Join Date: Aug 2003 Location: Western PA Posts: 1,408 | | | blot when trying to remove ink or other solvent type spots...rubbing tends to promote migration of the spot to extend the size of it |  11-04-08, 02:32 PM | | Member | | Join Date: Nov 2008 Posts: 1 | | | You're all lifesavers Wanted to say thanks. This worked great. I was frantically trying to figure out how to remove the ink from my new sofa and was lucky enough to land here. I used rubbing alcohol and blotted...no more ink mark. |  11-05-08, 10:21 AM | | Member | | Join Date: Aug 2000 Posts: 17,214 | | | Thank you for providing feedback. doityourself.com is glad to be of service. |  03-03-09, 09:47 AM | | Member | | Join Date: Mar 2009 Location: usa Posts: 1 | | | ink on microfiber The rubbing alcohol worked for me today big time. I ran my ball point pen on my recliner by mistake. Read the advice on this site, took a Q-tip and the ink came off with almost no rubbing at all and it left no "water type mark"..Amazing! Thanks to all who gave this good advice. Orion |  03-03-09, 12:25 PM |  | Topic Moderator | | Join Date: Aug 2003 Location: Western PA Posts: 1,408 | | | glad to hear that it worked out for you..thanks for posting your results | | Thread Tools | | | | Display Modes | Linear Mode | Posting Rules | You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -7. The time now is 04:49 PM. | Sign up for our FREE newsletter! Find Qualified Local Contractors Sponsored Ads |
