cancel
Go Back   DoItYourself.com Community Forums > Plumbing, Heating, Cooling, A/C, Fireplaces, Air Filtering & Water Conditioning Systems > Boilers - Steam and Hot Water Systems
Boilers - Steam and Hot Water Systems Radiators & Baseboard Heating Systems. Installations, Repairs, Maintenance, Services and Technical Advice
Thread Tools Display Modes
  #1 (permalink)
Old 03-12-09, 10:57 AM
Baseboard Heat Not Working Downstairs
I have a boiler system with two circulators, one for the upstairs and one for the downstairs. The downstairs has two branches and one of the branches is getting hot water fine (the shortest one), but the longer one appears to fail to get hot water past the first register.
Could it be clogged? If so, how would I clear the clog? I have no bleeder valves on this part of the system on any register.
Thanks!
  #2 (permalink)
Old 03-12-09, 04:05 PM
Before you go looking for a plug check other items. are you sure pump is on? Have you had the system open for repair? Could be air. Do you have the proper water pressure? Usually a plugged system would mean its dirty.
  #3 (permalink)
Old 03-12-09, 04:14 PM
just re-read. No vents could be a problem. Do you have any drains [hose connections]on pump so you can flush back through the system?
  #4 (permalink)
Old 03-12-09, 04:47 PM
NJ Trooper's Avatar
Topic Moderator
Quote:
Could be air.
I agree that it could, and will say that it PROBABLY is... unless of course there are valves closed that should not be.
AIR is just as effective a plug in a pipe as an old potato chip bag.
Why not post some pics so we can see what you are working with? free account / Image hosting, free photo sharing & video sharing at Photobucket / upload there / drop link here so we can view.
__________________
The following statement is true.
The previous statement is false.
Tags
baseboard, boiler, not working
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
