cancel
Go Back   DoItYourself.com Community Forums > Interior Home Decorating and Design Center > Blinds, Shades and Shutters
Blinds, Shades and Shutters Selections, styles, types, measuring, installations, maintenance and repairs.
Thread Tools Display Modes
  #1 (permalink)
Old 11-21-08, 03:09 PM
how to cut bamboo blinds
Does any one know how I can cut bamboo blinds? Would a fine tooth hacksaw work? Thanks
  #2 (permalink)
Old 11-22-08, 08:22 AM
Shadeladie's Avatar
Super Moderator
Hi and welcome to the forum.
This answer is from BLD, posted a couple of years ago:
"Yes you can trim them..
The trick is to roll it very tight and then stack it on one end against a flat surface to make sure its is even.. Simply place the shade, [headrail and all assuming its wood] in a 12" chop saw with at least 90 teeth and trim off what you need..
Make sure you go very slow"
Hope this helps!
__________________
"The secret of getting ahead is getting started" - Mark Twain
Please have your pets Spayed or Neutered.
  #3 (permalink)
Old 11-22-08, 08:34 PM
BLD BLD is offline
Please test out the chop saw scenario by cutting the shade long beforehand.
If you do not have a chop saw and expensive blade, a fine tooth japanese style hand saw would be a wise investment for under 20 bucks.. Depending on the material, a fine tooth hand saw may be the better choice to avoid splintering.
  #4 (permalink)
Old 12-19-08, 09:00 AM
Cutting bamboo shades
You can also use a Dremel to saw the edges if the shade doesn't fit horizontally in your window...it is tedious but worked well.
HTML code is On
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Content Relevant URLs by vBSEO 3.2.0
