cancel
Go Back   DoItYourself.com Community Forums > Interior Home Decorating and Design Center > Blinds, Shades and Shutters
Blinds, Shades and Shutters Selections, styles, types, measuring, installations, maintenance and repairs.
Thread Tools Display Modes
  #1 (permalink)
Old 02-05-06, 04:47 PM
Members
repair plantation vinyl shutter tilt bar breaking off
The previous owner of the house we now own installed a number of Plantation, vinyl, 3.5 in. slat, interior shutters on the windows. The slats are notched in the middle of the interior edge where the tilt bar is attached. During shutter construction, a "T" fitted plastic piece was inserted into each of the slat notches and then bases of those pieces were matched up and slid into the U shaped piece of plastic tilt bar which then had it's ends sealed. The best description of those plastic "T" connectors is that they resemble a cuff link "T" which when inserted into the slat notch has the two ends of the "T" captured in the slat, and then the "cuff link" part would be slid up into the tilt bar to allow all the slats to tilt in unison. (A picture is worth a 1000 words!) This made a nice installation until the sunlight degraded the plastic "T" connectors (ever heard of UV rays?) between the tilt bars and the slats and the tilt bars are now all falling off. This seems to be an easy fix if I can find replacement "T" plastic connectors, which I can't seem to. Anybody have a source, advice, or comment? Thank you very much.
  #2 (permalink)
Old 02-05-06, 09:36 PM
The only company I've dealt with that used that type of connector is SHUTTERSMART .
Of course yours may be a different brand, but you may get lucky and find their part will work.
Good Luck!
  #3 (permalink)
Old 02-07-06, 02:52 PM
Annette's Avatar
can you determine the brand/manufacturer of your shutters? if so, contact them.
  #4 (permalink)
Old 07-04-09, 07:42 AM
shutter pins
I just read your post about the plastic T-pins connecting your tilt wands on your shutters. I am in the exact same predicament. Did you ever find any replacement Ts?
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
