| F150 starting problem I have a 2003 Ford F150, automatic, 6 cylinder with 90,000 miles. Truck runs very good, idles smooth and still gets reasonably good mileage. At times it starts slowly. The engine turns strong but just will not catch right away. It will usually take anywhere from 5 to 15 seconds to start and does not always start the first time I turn the key. It seems to happen more often when the truck is on fairly level pavement or the front of the truck is slightly lower then the back end. It can happen whether the truck has been running for several hours or first thing in the morning. Once it starts it idles perfectly. My usual mechanics performed an overnight pressure test and the fuel line is not losing pressure. They have not been able to pin point the problem because it has always started fine the 2 times I have left it with them. I took it to the local Ford dealer and spent $700 dollars to fix what they said was causing the problem. They replaced some seals around the manifold that were cracked and caused the truck to run lean. The next morning it did the same thing. I can't help thinking this is some sort of fuel issue but I don't know what to do next. Any ideas would be appreciated. I've been dealng with this for several months. |
