cancel
Go Back   DoItYourself.com Community Forums > Cars, Trucks, RV's, Boats and Outdoor Power Equipment > Automotive Service and Repairs
Automotive Service and Repairs Cars and Suv's Only
Thread Tools Display Modes
  #1 (permalink)
Old 08-01-09, 12:03 PM
Question 2005 Toyota Camry SE V6 replace serpentine belts
Does anyone know where I can find information on how to replace the serpentine belts in the Toyota Camry SE V6? It is two belts and the engine is a 3.3 liter.
I have tried to located something online - but can't find anything. Does anyone know how to do it - or where I can find info.
Thanks,
Susan
  #2 (permalink)
Old 08-01-09, 07:34 PM
Toyota uses an adjustable pulley/tensioner you have to loosen the bolt in the middle of the pulley (some have a nut on the back side) and adjust the bolt that it has. The P/S pump is usually one of the adj pionts also the easiest way is with the r/front tire off and the splash panel off there isn't much room to work in there and it's located on the back side of the engine on the bottem, you will have to loosen the piviot bolt on the pump then you have to loosen the lock bolt for the adjuster bolt and can turn the adjuster bolt on that.Please make sure if you go after that one this way that the car is supported by something other than a jack on that side. You will have to be under the car to do it.
  #3 (permalink)
Old 08-02-09, 09:15 AM
Gunguy45's Avatar
Topic Moderator
Autozone has the same basic info that MM posted.
I was going to answer yesterday...but I wasn't sure of the engine..it didn't show in the repair gude for your car.
__________________
Vic
I'm no expert, but don't tell my wife that.
Tags
belt, camry 2005, repair, repair manual, serpentine
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
