Quote:
Originally Posted by Mackey
What can I use as a replacement hose clamp from oem hose clamps. The standard replacement worm gear clamps stink!
They have to be tightened in the fall when outside temps drop because of leaking........oem types don't leak (the compression spring type).
Are the compression spring hose clamps available at the local auto parts store?
What do you hp muscle car guys use on your 500 HP big blocks to prevent leakage at the hose clamps?
I have used both kinds. Sounds to me like you need new hoses! Once the rubber gets hard it can crack internally and lengthwise. Either clamp will work on a non pressure hose, but the screw clamp is best for a pressure situation. Don't buy cheap junk!
