cancel
Go Back   DoItYourself.com Community Forums > Cars, Trucks, RV's, Boats and Outdoor Power Equipment > All Trucks, Campers, Trailers, RV's and Motor Homes
All Trucks, Campers, Trailers, RV's and Motor Homes All Trucks Includes Pickup Trucks. All Tow-able Trailers, Camping Trailers, RV's, 5th Wheelers and Motor Homes, Etc.
Thread Tools Display Modes
  #1 (permalink)
Old 10-27-09, 07:30 PM
HPI HIGH's Avatar
a4ld trans prob
i just bought an 1988 ranger stx 4x4 and no matter what gear you select it will go forward even park very weird i know if anybody has encountered this problem or has any ideas im open for suggestions.
  #2 (permalink)
Old 10-27-09, 09:47 PM
1st, 'i' would have a helper,move the shift lever-p-r-n-d-2-l-L.
& you,or some one that understands what 'should be happing,
watch the trans-shift arm.
post back- if the trans selector lever/arm is moving,as with the selections,
  #3 (permalink)
Old 10-28-09, 01:59 PM
HPI HIGH's Avatar
i did that that today and is shifting as it should.
  #4 (permalink)
Old 10-29-09, 09:55 AM
my'guess' linkage inside- loose/damaged.
'if' you are capable-pull pan & inspect.
  #5 (permalink)
Old 10-30-09, 05:49 PM
HPI HIGH's Avatar
LINKAGE WAS FINE FOUND OUT CLUCHES ARE WELDED TOGETHER FROM PREVES OWNER RUNNING IT WITH NO FLUID
  #6 (permalink)
Old 10-30-09, 06:03 PM
that 'aint' gona be a cheap repair.
but even with the chutch pack galleded/welded together.
the park pawl/gear should not allow it to go foward in 'park'if you are involved in this repair/replacement- make sure the trans fluid-COOLER is cleaned properly.
  #7 (permalink)
Old 11-03-09, 12:14 PM
HPI HIGH's Avatar
I FOUND ANOTHER TRANNY FOR $175 and installed it . new tranny works fine thanks for the help.
  #8 (permalink)
Old 11-03-09, 08:16 PM
did yuo flush the cooler & lines?
IF' not-it aint gona work fine ,for long!
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
