cancel
Go Back   DoItYourself.com Community Forums > Cars, Trucks, RV's, Boats and Outdoor Power Equipment > All Trucks, Campers, Trailers, RV's and Motor Homes
All Trucks, Campers, Trailers, RV's and Motor Homes All Trucks Includes Pickup Trucks. All Tow-able Trailers, Camping Trailers, RV's, 5th Wheelers and Motor Homes, Etc.
Thread Tools Display Modes
  #1 (permalink)
Old 04-28-08, 03:02 PM
1997 chevy silverado z 71 runs rough no power
my truck has no power i changed the o 2 sensor fuel pump and cleaned the maf any one have any ideas
  #2 (permalink)
Old 04-28-08, 09:04 PM
Speedwrench's Avatar
how many miles are on it?, have the plugs been changed? have the injectors been cleaned? have you examined the engine in the dark while running to see if it had spark going outside the wires?
life begins when the kids leave home and the dog dies
  #3 (permalink)
Old 04-28-08, 09:34 PM
Go Sooners! I'm from El Reno, OK. The truck has 101,000 miles and the injectors haven't been cleaned. Yes, I have checked it at night and I did not see a spark.
  #4 (permalink)
Old 04-29-08, 05:25 AM
would suggest you have codes read for a starting point might also be a good idea to run it by an exhuast shop to check for a exhuast restriction.
  #5 (permalink)
Old 05-06-08, 07:12 PM
ukrkoz's Avatar
Common problems
1. plugged fuel filter causing low fuel pressure in the fuel injection system.
2. plugged air filter not allowing the proper amount of air into the engine.
3. fuel pump is worn providing low fuel pressure to the fuel injectors.
4. routine tune up necessary
  #6 (permalink)
Old 05-06-08, 08:34 PM
forgot to add have you ran a compresson check on your engine? if not please run one and let us know what it is. to run properly then engine should have all cylinders within 10 percent. you must have good compression, fuel and spark for starters.
Murhpy was an optimist
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
