cancel
Go Back   DoItYourself.com Community Forums > Plumbing, Heating, Cooling, A/C, Fireplaces, Air Filtering & Water Conditioning Systems > Air Conditioning
Air Conditioning Central A/C Whole House Systems and Window A/C Units. Installations, Repairs, Maintenance, Services and Technical Advice
Thread Tools Display Modes
  #1 (permalink)
Old 11-05-09, 06:37 PM
Ducted ACSON not working E03
Hi
Any help would be most appreciated.
I have an acson ducted unit, the outdoor compressor does not seem to be working. I have checked that all cables are plugged in, the fuse box seems ok. The LED control inside says flashing E03 which from research may be Compressor 2 high temperature(overload).
Some of the indoor vents have air coming out but it is not cold. Some vents have no air coming out.
I have read that a thermostat reset may help but I dont know how to do this.
Thanks in advance.
  #2 (permalink)
Old 11-06-09, 01:09 AM
GRIMKNOTME's Avatar
Is this a ducted mini-split
----Some of the indoor vents have air coming out but it is not cold. Some vents have no air coming out.---
Sounds like it is zoned with a zone not working.
I would reset all power and see what happens which will reset your t-stat unless it has batteries.
  #3 (permalink)
Old 11-07-09, 04:04 PM
ducted yes but no mini-split
I have gone through all the menu options and cannot find any zones.
I have turned main powers off, will this reset the t-stat?
thanks for the tip
  #4 (permalink)
Old 11-08-09, 05:18 AM
GRIMKNOTME's Avatar
Cutting all power off should reset t-stat , unless you have batteries in it , try it , but if outside unit not working after that ,a high pressure switch in o.s unit may be keping it from running
One end of this contactor should have 220+- volts on it with all power on to unit , when you turn on ac/heatpump the piece in the middle should pull in , (you may have two bars instead of one) , and you get the same voltage thru both ends of contactor is in outside unit as far as getting heat from heat pump , possible problems ; lo/high pressure switch = no freon,bad fan motor bad switch ,control board
If contactor does not pull in on heatpump with heat/cool on at t-stat with power on , you have a prob b4 outside unit
DO NOT FINGER TOUCH ANY METAL WIRING OR YOU WILL FEEL IT
The vents with no air coming out may be returns sucking air back in I hope.
Trackbacks are On
Pingbacks are On
Find Qualified
Local Contractors
Select Service:
Enter Zip:
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
